i have a 2 terminal ballast resistor,four prong ecm box and a five terminal ecm harness.when i first converted it over,it worked great,no problems. i heard its normal for the resistor to get burnin hot?form what i read on other posts.people havin similar problems. what about the coil gettin real hot? i replace the voltage regulator connector today,i saw it was worn out the terminals looked bad on it,it didn't fix the problem.the voltage regulator it self gets kinda hot.
