Thanks guys. Probably gonna use a champion. Don't need original as the entire car is modified from original & to recore mine is $$$$.
I put my champion in today . It is shiny and pretty. Then came the die grinder to enlarge the holes because they were off by about a quarter inch everywhere. Then came the drill to drill holes in the bracket to put the shroud on because those holes didn't line up, only to find that when all was said and done, the shroud doesn't fit flush with the radiator because the brackets for the shroud stick way out. But she sure is shiny. But when all was said and done, I am ok with the crappy fit for only $200 for the 3 core. ..... And.... I took it out in the 90 degree air and beat the snot out of it. The best I could get was 210 degrees creeping around and beating it. So I guess it works. Good luck.
