looks exactly like the pump that came off of mine, even though mine wasn't a crate. it was putting about between 8-9 psi. but i don't see where it was ground to clear the block, so i can't be sure that it is the same.
Where exactly should I look on the pump for grinding for clearance?
Thanks.
