North Alabama
Monte, my 8082-3 clearly says HP on it and was listed as such.
OK, let me rephrase. ALL Dominators, with the exception of the Marine unit, are listed as HP carbs(but no HP series), however, there are NOT 3 levels of Dominators. There is no Dominator, Dominator HP and Dominator Ultra HP. Dominators are standard or Ultra and that is it. That is all I am trying to make clear here. There is no "in between" series. When Dominators started getting screw in bleeds vs press in, they got the HP name, but they are still just standard carbs, until you go to the Ultra.
Your 8082-3 is a 2 circuit carb, which is obviously a standard Dominator, regardless of the HP tag. The -1,-2,-3 etc, is nothing more than calibration changes, since the original version of the carb came out.
Monte
