why not bolt on a gearvendors to the 727? you can build a bullet proof 727 and still have options on gearing with a button.The 727 will bolt in easy,gearvendors easy bolt in,cut shaft and burn the sh!t out the tires
once you've stroked it,you'll wish you stroked it sooner
