Ran jumper wire from alt case to body no change. Used jumper cables from bumper bracket bolts to motor mount bolts and power steering pump DMV jumping all over the place. My ground cable runs from intake manifold bolt to sway bar bracket bolt on k member. Being manifold and heads are aluminum could this cause grounding problem?
