Scott no one cares about those tiny engines!!!!! Just kidding
Ron
Yet all the pictures posted above are of /6's or small blocks
He said he wanted to see blue engines with manifolds painted ...
You can't see bolt head markings with the hood closed while doing the speed limit either ...
PLUS ... if you actually READ his question you would have seen that your answer has no bearing on the question ...
What are people doing to their manifold studs and nuts to prevent corrosion?
There is nothing there about BOLT HEADS ...
