There's some relatively small and cheap systems out there that would work nicely on an older vehicle...You could buy one with a motion detector even the cheapies have an adjustment for sensitivity..Then hook up a trigger to the door jamb switch for another level of protection...It's limitless on the system..Of course a system that dials you would cost more...Just be prepaired for the false alarms with even a cat sending you into a panic with a phone call...
