Powder is powder. It needs proper prep to stick, the proper thickness to cover smoothly and the proper temp to melt. The question is ... will your wife let you use the oven and is it big enough for your stuff!
The powder coater I've used is so damn cheap its just not worth the effort or expense - and he already has every color under the sun !!
