This has been almost two years in the making, but here we go. Dyno time scheduled for tonight !
Its a 440 based 520" stroker using a stock '68 440 block. +.030 4.375 Stroker kit is from 440 source w/30cc dished pistons. Heads are Indy EZ 295 CNC's finish prepped by Dwayne Porter, compression 10.5-1, cam is a Bullet Hydraulic Roller 252/258 @ .050, .622 lift with 1.6 Crane rockers, 110lsa, Indy Dual plane opened up to max wedge ports, Single line external oiling. 1000cfm Quick Fuel 4150.
This engine was originally intended to be used in a 1970 Super Bee with all steel and full interior, and everything that came from the factory including no cage, but that car is sold. I'm back to owning my old 65 Coronet wagon with a great running healthy 470, so I'm not even sure what I'm going to do with this engine at this point...
I will be sure to update (hopefully tomorrow)with dyno numbers and a pic or two. I'm not going to do any guesssing on HP. This dyno is un-happy, so I won't be expecting any magazine numbers, but I would be disappointed if it didn't crack the 600 mark.
Care to share your guesses??
