RR, I'm going to say that 38 degrees total no vacuum is where I'd want to end up. Those low compression smog motors like spark advance.
In the same way, getting the advance in faster will help wake up the engine. So 15 initial, 38 total, all in by 3000 rpm would be my cookbook answer.
R.
