What are you guys with an aluminum headed hemis running for timing. Mine is a 528, stage V aluminum heads with 2 Eddy 650 AVSs on the street. CR is roughly 10.4:1. Right now I have my MSD set at 17 initial with a total of 35 total. Seems to start OK with the 17 degrees of initial.
That should work really well. Usually 32-35 total worked well for my 472 (even with all of the problems I was having)
