the only difference in the fenders are they are about 1 1/2"-2" wider and the wheel opining is larger than the 1/2 ton model.
so the 1 1/2 ton front clip should fit the 1/2 ton truck.
Ron, I would never outright question your knowledge but I'm not too sure about the differences you mentioned in the fenders. In this pic you can see that the filler panel below the cab is longer than on a 1/2 ton truck and the fenders extend down to the bottom of it. Comparing this pic to my own '37 makes me think that the 1.5 ton fenders are "taller" too. I've noticed this same difference on my '68 D500 also.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
