this is exactly where i'm at. wheel won't return to center, wants to wander while driving it. works ok in 'beast' mode (belt off). i've been fiddling, and fiddling with that valve location, nothing except i've stopped the wheel from turning on its own at a stop. amazingly frustrating and the FSM is little help. and the carpenter bees didn't help! PLEASE let me know if you find out something from Firm Feel. my next step is to rebuild my lower control arms and the steering coupler. why? i don't know what else to do. it was a working unit until the original pump went south and now i'm not so sure i ever had a problem with that one!
I'm sorry to hear about your situation, but it's somehow a huge relief to actually hear from someone with the same problem.
I've got one more trick I want to try before I give up and contact Firm Feel. Just not sure when I'll be home long enough to try it.
