Traction control on. Turning it off is worse.
I was hoping someone had a tire recommendation, or ideas for things to address, I might lower it an inch or so. Just have no clue about the independent rearend stuff.
What's the 12.57 in the 1/8 mile. I been 7.78 but the track was flypaper.
Try traction 1/2 off (hitting the button) and full off (holding down the button until it chimes) - Nitto NT55R's are a good everyday drag radial that even works in the rain.
Also, do not hit rev limit when doing burnout, it'll retard the timing and ruin your run by knocking down power - stay under 4500
