A easy way to see the taper is to put a used ring in the cylinder up at the top square it up, measure the gap, then push it to the bottom of the bore and remeasure. Im betting .008+
But should probably last 100K anyways, might start using oil pretty fast though
[color:"red"]65 Hemi Belvedere coming soon [/color]
[color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
