I guess I want a tight convertor that will flash when needed but not ber so sluggish just cruising around or highway driving,
You need to talk to the manufacturers and give them your information on the engine, car, trans, gear, and tires, and what you want from the converter.
I had Ultimate build me a tight street/strip converter. It is a 9" 5,000 RPM flash stall converter that is so tight it seems like an 11" converter until you really hit the throttle. It is exactly what I asked them to build me, but it was a bit pricy, just over $1K plus shipping.
