The teeth on the ring face up towards the steering wheel and the wavy washer sits on top of the flat center area then the housings go on.
It is a pain in the back side to get the washer with the teeth to sit in flat on the tabs. It took me a little while to get it in place. This photo was as I was taking it apart. Mine is a column auto car.
David
column ring.png (225 downloads)
