The picture you show in the first post is your lifter acceration rate,you can figure it by entering your seat to seat and @.050 duration numbers in the camshaft files.
For the head flow chart ,you need to manually enter in correct valve sizes for starters,then enter in the flow at each lift number manually.Do you have a flow sheet for your heads? If not ,you can use a generic head flow chart from the program,but your results won't be as accurate.
Hope this helps,...Keith
ya i have my head chart.
no hemi chart but wedge,canted,2/4 calve...
i am looking for eddie,indy,B1/bs,MC the popular heads to start.
i did use the auto select on the lifter,cam info.i will get cam specs out of a cataloge and so on.
