I had my '70 Rally tach rebuilt and run it with MSD + the correct signal converter. It works in the sense it moves to the right as revs increase. Is it accurate? No +/- 300 RPM... mostly plus. I measure against the EFI computer that counts crank pulses and should be accurate.
Think I'll add a tach on the column...
