I was hearing a groan when turning last summer.
In the picture above from the archives, it appears to me that this is how mine are set up...with the larger diameter of the bearing to the INSIDE....the Napa tech was saying that "usually" the larger diameter would go to the OUTSIDE....
So there is a seal under that bearing between the race and the mounting flange, correct?
