The Cordoba/Charger/B-Fury & Monaco/Coronet buckets will also work...but they will be 1970s era comfortable. Later model mini-vans and K-cars will up the selection and might not be to bad of a fit. Measure your track width and then go to the local yard and see what is close and if you like it.
