"Stored Energy" is what your looking for and a .920 bar will not do it. You want the newest and the smallest bar you can get your hands on. In a perfect world you want the bar turned all the way up just so the body is just off the bump stops (and that is with the bump stops shaved down to less than an inch thick) You can always control compression and expansion with the shock and limiters.
Just my opinion.
if you tell us where to get them i think we would both try them.
