If I remember right the ones Ehrenberg sells do not have a retainer to keep the push rod in place. Some were concerned that it is possible for the push rod to fall out of the master cylinder if the brake pedal is bumped or pulled back too far, (this means no brakes) I guess it actually has happend to some people. Ehrenberg's suggested fix was to silicone the push rod into the master cylinder.
