Originally Posted By mopartuner
working on a 68 cuda with stock wiring harness.looking for a live that is energized with the key on and key start position.cant seem to find one?
there should be aonly one wire is energized in the start position, it goes to the coil side of the rignition resitor to provide 12 volts to the coil when the starter is engaged, it is either brown or blue, CRS disease realcrazy I have a 1969 FSM, not a 1968, that i can look that underhodd schematic up and tell you what color it is in 1969 work I'm pretty sure there the same colors form 1962 and later for the B bodys shruggy
BTW, are you looking for a spare ircuit to use for some other purpose? If so I may not be able to help on that, sorry confused
