I have read a lot of the disc-o-tech and online forums pertaining to the swap but wanted to know specifically what you all thought?
I would use the spindles you have. Why drag together a bunch of used parts and hope they work together? There are kits that will bolt up to your drum spindles and work great.
66 B body drum spindles -
