DC any idea how much vac it is generating? I want to do this myself.
I put one on my 360. Mine doesn`t generate much vac but it is enough to keep oil from covering the intake and valve covers. It really depends on the exhaust and back pressure on how much vacuum you get. Also it depends on where you install it and the angle of the pipe.
