It will bolt right up, perches are the same, but the 66/67 Dana is roughly 3/4" narrower, the 69 "may" fit with regular wheels & carefull choice of tire, but keep in mind the 66/67 cars have small wheel wells. May need a different wheel offset? Every bit of room helps, I'd look for a 66/67 Dana if I were looking.
