I checked the balancer and it looks to be symmetrical all the way around on both sides and does not look like the external balanced units that I saw when I searched online. I pulled the inspection cover on the trans and it definitely has the larger converter but I do not see any weights on the converter so maybe I got lucky with a forged crank. I searched online and the pics I found showed the balance weight on flexplate side of the converter and the one I have only has 4 tabs welded on it for the flexplate mounting bolts. Anything else I should check? Thanks for the help.
