Hughes has a nice ridged alum plenum pan package with everything need to replace the cheap tin plate mopar used. 100 bucks or so. well worth the price.
if the intake has ever been removed it is sure to be sucking oil at 80,000 miles.
already been said so I am saying it again.
Hughes plenum pan package even if you have a shop/mechanic do the labor use the package from Hughes.
