Originally Posted By csmopar
If I may ask, where on the windshield have you found it easiest to start at?
I always try to start somewhere around the top 6 inches or so from either corner. Work one side around the corner and down to the bottom and then back track and work the opposite direction. Typically once you have the top and sides they will rotate out without any damage. Once you have 3 sides done lift the bottom corners back and up and let it rock on the radius at the bottom and it will release. twocents
...FAFO...
