I was at a buddys shop and a car got fired and let idle for a while....but the auto trans was in Park....it idled for about 5 or 10 minutes and then it was put on Neutral to check oil level on the trans and it was almost dry.
Question is....will an automatic transmission het damaged that way or it wont harm a thing unless its put into gear and driven while low on oil ?
Entire Thread
Subject
Posted By
Posted
will an auto trans get damaged idling on P and N with no oil
