I'm in the process of wiring a 72 Duster with a 440, Mopar orange ignition box and internally regulated Denso alternator. I'm looking for any wiring diagram that can help me with this. I already bypassed the AMP gauge and ran the shunt wire from the alternator to the starter relay. I need to know how to bypass the factory voltage regulator and where to pull the ignition switched wire for the denso alternator. I can't find any wiring diagrams that even remotely explain this. Any help is appreciated!
