...UPDATE... upon closer inspection looks like something has moved / shifted....Look where the bare metal shows no paint and you'll see it. This was after maybe 20 min on dyno...Also still waiting on build sheet, cam card, among other things promised. Patience is wearing thin.....
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
