Not....Bit off more than I could chew, add hernia surgery to that, and I may not make it....at least with none of my junk. I need a hood, coil overs, push rods, convertor, dyno time. The hood is my biggest problem at the moment. Off on short term disability and I have not seen a single dime yet.
Going to have to run my engine builders 69 Hemi Barracuda instead....I like the wheelies it does, so that's a plus....
Those big dumb wheelies are overrated! Sure they are fun, but expensive as well.
New Ron's fuel pump should be here in the next couple of days, drain antifreeze and fill with distilled water, nut and bolt everything underneath, tag truck and trailer, and finish Raceral's tranny for his Satellite when the rest of the parts come in. Getting the bug bad now that its warming up. Beep
