I towed my 3,300 lbs car on a heavy u-haul trailer a few times about 90 miles one way in flat northern Il. 4 wheel disc brakes worked fine, engine had enough power to pull it no problem. I would add some leafs or load levelers on the rear, and make sure the OD is off.
