Any good mandrel bent 2.5 system should be fine unless you are pushing more than 450hp.If you don't want to spend alot even the summit or jegs house brand kits are fine with the mufflers of your choice.Throw on some repro tips with larger inlets and your done for a fraction of the cost of a tti system.
