Not sure what wheel size will work with all this info. I did find another set of 15 x 7 rally wheels but here is the spec. 5 x 4 inch bolt pattern with 4.25 inch backspace. Will this bolt up to my gtx and fit correctly? What tire size will work? I would like larger tire in the rear.
Joe
I know my Charger has a 5 x 4.5 inch big bolt pattern, so I believe the GTX is the same. Those are the small bolt pattern.
So, they're not unilug?
