Adco still makes bars for them, not sure if the front is any bigger than a factory taxi/cop bar...
Yes, but if I'm not mistaken (I had an old Adco rear bar once in a box) they mount differently from the OEM setups. Hmm...worth a 2nd look though...let me check it out..thanks!
I put one on the front of my 88 dippy at one time, I think it was 1/8 bigger than a cop bar. It mounted in the same location as stock. After about 10,000 miles one of the end links ripped out of the lower control arms so you might think about bracing them.
A new iron curtain drawn across the 49th parallel
