You should be able to rotate the oil line out towards the header just enough to miss the alternator without getting into the headers. At least that is how it looks in the picture. Not sure if you have anything else in that area. You might need to get another line built that is a couple of inches longer but that would be cheaper than building a custom alternator bracket or a new alternator.
