Of the various types of power steering pumps that our old Mopars came with, is there any one of them that works better than the rest, particularly on a big block application? If so, if you could explain why it is better I would appreciate it. Also, if the same pump type could have been used on a slant six, small block and big block, did they use different size/type of pullies or were they all the same? Thanks.
