The key to this is knowing the vehicle and it's history. As Rickster mentioned, going across the auction block and a buyer has no clue what else is screwed up with it would probably go for 2k.
You could offer more and be comfortable then hope he takes it.
If you were planning to turn up the wick on performance like with a supercharger, you would have to rebuild the engine anyway.
