Just got this table today. For those old Mopar gauges, they read based on the resistance of the sender. For the temp gauge it looks like this:
C = 75 ohms
1/2 = 27 ohms
H = 10 ohms
I am replacing the sender this afternoon but I was wondering about the temp readings cnxt posted here; The external radiator and housing readings of 205 seems a little higher than many on this board like to see.
I have read many posts where people have said they like to see temperatures around 200 and that 210 is too high.
Is that because the external readings taken with a laser are a little higher than the actual internal temperature or running at <200 is unrealistic without a push fan?
