you'll get there. You need to find what the car wants for the IC location then use the wheelie bars to slightly control and help steer it on launch. I will see what I have in pics when I was making them and email them to you. One of the reasons I decided to make my own is the upper mount is between the tire and spring so I had to bend the upper bar around the shock. I also added a cross bar between the wheel houses as I have see others wobble behind the X.
didn't find many pics but I emailed them to you.
