Quote: Did you get the 400 Dist or order the 440 and cut the shaft?
400 Distributor.
It is up and running, I really like the easy access to the advance Springs, right under the rotor. The Rev limiter I need to play around with, the tiny adjuster seems to jump all over the place rpm wise, and it seemed to kick in early. I will get it figured out and I might just buy their external Rev limiter box as it would be easier to set and to do quick low rpm settings just to make sure the Rev limiter is working.
