stock rods it is a steel crank with the correct converter/flex plate I did set the thrust bearing when i assembled it. it seems strange i still had 30 psi on the outlet of the trans cooler going back to the trans. it is the factory steel line and i dont see it kinked anywhere thought it just drained back to the pan
