Re: My 337 MW intake....
[Re: ScottSmith_Harms]
#1774987
03/11/15 12:40 AM
03/11/15 12:40 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
FWIW I have messed around with multiple Xram setups using dual 3/4" pop offs over the years (30 or so years), most were Hemi's and small blocks. To date I've never had an intake crack when it "sneezed", the valves did their thing. Having said that, a larger opening with a plate, or more valves, wouldn't hurt any, the more pressure relief and the faster, the better.
Why the 140PSI valves, waaaay to much, IMO. The manifold is normally under vacuum .
I don't think I would want any more then +50 PSI in that intake.
