Yes, exactly. No argument with you cjskotni.
If you did not run a bypass and connected directly to the alternator then the load would still cross the bulkhead in the event the engine was not running and the device needed power.
That specific scenario is less common and would carry a lighter load but in the event you are running new lights or a large amp or large electric fans, I would personally run a bypass and create a new distribution point inside the engine bay so those loads could pull directly from the engine bay.
