Re: weight difference 8 3/4, 9 in and d60
[Re: Pacnorthcuda]
#1770156
03/04/15 01:59 AM
03/04/15 01:59 AM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
Someone has done their home work Bonus question; who and where was the Hypoid invented???
Tesla. Another factoid is that the lower the pinion to the ring relationship the stronger (think Ford 9") simply because of greater tooth to tooth contact. Also why is less efficient in terms of drag. A trade off.
You are incorrect sir... both accounts. The first Hypoid ring and pinion was invented by a trio of companies and patented in 1935. Ford motor company, Shell oil and The Gleason Works.
As for the 9" being stronger due to its pinion off set, one of the contributors to its weakness is its pinion offset. The fact that the crown is engaged by the pinion almost under the crown center line creates crown deflection due to the vector forces alignment with regard to the ears of the carrier bearing journals (limited to no lateral support). Meaning the vector forces are trying to push the crown and pinion away from each other deflecting the carrier bearing journals (one reason for draw thru cap bolts)and ahead of the rear pinion bearing. The reason for this potential deflection is the further the force generation from the bulk of the casting the greater the deflection will be (BTW the 8 3/4 has similar issues). Un-like the 12 bolt and Dana where the force is generated directly between the caps and over the rear pinion bearing. This brings me to the fact that a 9" needs a crown support to keep the crown from folding over in high HP apps as well, another feature (this time from ford)is the rear pinion bearing to bolster the 9" strength for everyday use, with out it. the pinion head simply pops off.
You are correct that more tooth engagement typically relates to a stronger gear set due to less tooth deformation but the gear on the 9" does not suffer from tooth deformation it suffers from system deformation.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Entire Thread
wyldebill
03/03/15 06:35 PM
Locomotion
03/03/15 06:48 PM
moparguy7074
03/03/15 06:50 PM
dogdays
03/03/15 06:58 PM
68shifter
03/03/15 07:04 PM
moparniac
03/03/15 07:08 PM
BradH
03/03/15 11:20 PM
W.I.N. Racing
03/04/15 04:30 AM
Pacnorthcuda
03/04/15 04:50 AM
W.I.N. Racing
03/04/15 05:59 AM
W.I.N. Racing
03/06/15 04:36 AM
Moparmal
03/06/15 09:38 AM
MR_P_BODY
03/04/15 06:30 AM
SportF
03/04/15 06:48 PM
BradH
03/04/15 07:20 PM
Cudajon
03/04/15 09:06 PM
Wv68charger
03/04/15 10:15 PM
jcc
03/04/15 05:20 AM
Locomotion
03/03/15 07:06 PM
Quicktree
03/03/15 11:18 PM
Locomotion
03/04/15 12:40 AM
1967dartgt
03/04/15 12:48 AM
wyldebill
03/04/15 12:54 AM
MR_P_BODY
03/04/15 01:02 AM
justinp61
03/04/15 01:07 AM
dvw
03/04/15 01:19 AM
MattW
03/04/15 01:25 AM
Quicktree
03/04/15 03:19 AM
dvw
03/04/15 03:35 AM
Quicktree
03/04/15 03:38 AM
dvw
03/04/15 04:24 AM
1967dartgt
03/04/15 05:22 AM
1Fast340
03/03/15 08:25 PM
wyldebill
03/03/15 09:08 PM
beecrazy
03/03/15 09:39 PM
1Fast340
03/03/15 10:25 PM
perfmachst
03/03/15 09:49 PM
AndyF
03/03/15 09:52 PM
451Cuda
03/03/15 11:10 PM
fishy340
03/05/15 04:35 AM
skrews
03/05/15 09:17 AM
SportF
03/05/15 05:19 PM
DavidDean
03/07/15 02:13 AM
68roadrunner
03/06/15 05:04 PM
