Hey, that's right. I've done that on a front wheel drive car to replace the timing belt.
R.
I once accidentally did that on a French car (Forgot the socket wrench was still on the crank ).
After that it was time for some new valves, because apparently this car didn't have a woodruff key on the crank timing belt pulley
A breaker bar with a hammer worked fine for my 318 also.
